DIAdem
Does Diadem have a function to determine the number of dimensions in an array?
I'm working with a matrix, and I want to make sure it's actually a matrix.  If I use Ubound(MyMatrix,2), I get an error if the second dimension is not declared.  I suppose I could catch the error if Ubound creates one, but I cannot find a method in VB to return the number of dimensions of a matrix. Does diadem have any such function?
(4,894 Views)
Accepted by RussellSenior
You can use a few lines of vbs to determine the dimension. VBS does not offer the functionallity as far as I know.
Function GetArrayDimension(ByVal arr)
   GetArrayDimension = null
   If IsArray(arr) Then
     Dim i : For i = 1 To 60
       On Error Resume Next
       UBound arr, i
       If Err.Number <> 0 Then
         GetArrayDimension = i-1
         Exit Function
       End If
   End If
 End Function
(4,871 Views)
Thanks.  That's what I ended up implementing. Don't you have to use "On Error Goto 0" to turn error handling back on?
(4,869 Views)
Hi Russell,
If you don't use "On Error Goto 0" afterwards, the rest of your code will run with error messages suppressed, and you will find it impossible to debug.
Brad Turpin
(4,861 Views)
Hmm potentially I should have inserted an
on error goto 0
but it is not necessary. What might be wrong is that err.number does not end up with 0 but it does not influence the rest of the script if err.number is not checked.
on error goto 0
does two things. Reset the err.number to 0 and set the local error handler back to raise.
Local means that there is one for each level. If a function/sub does call
on error resume next
this does not affect called functions/sub nor does it effect the calling code.
Run the following example to have look. cr raises an error even if it was switched off by c and the final division by zero in the main code also shows up.
Option Explicit
dim txt
txt = txt & "e: " & err.number & VBCRLF
err.Clear
txt = txt & "e: " & err.number & " a:" & a() & " e: " & err.number & VBCRLF
err.Clear
txt = txt & "e: " & err.number & " b:" & b() & " e: " & err.number & VBCRLF
err.Clear
txt = txt & "e: " & err.number & " c:" & c() & " e: " & err.number & VBCRLF
err.Clear
MsgBox Txt
dim res : res = 1 / 0
function a()
  a = err.number
  on error goto 0
end function
function b()
  b = err.number
end function
function c()
  c = cr()
end function
function cr()
  cr = 101
end function
(4,805 Views)
Be aware that the err.number is also set back during initialize
Option Explicit
err.number = 4711
MsgBox err.number
MsgBox err.number
will show 0 in the second box
(4,803 Views)
