DIAdem
Does the 9.0 Property "ChnValSet" support sending strings?
I'm using ChnValSet, but DIAdem doesn't like me sending in a string as the value parameter. I'm pretty sure the channel is configured properly, an an "ASCII" type.
(3,798 Views)
This is also not working with the CHDX command, so there must be a bug somewhere.
(3,798 Views)
Please use CHT(index,channelnumber) to set values in a text channel. Please refer to the online help for more details
(3,798 Views)
Please use CHT(index,channelnumber) to set values in a text channel. Please refer to the online help for more details.
CHD and CHDx can only be used for channel with numeric data.
(3,798 Views)
I'm not scripting in DIAdem, I'm using an automation reference (To.Command and To.Data). Can you use CHT with those? Thanks.
(3,798 Views)
