DIAdem
Error: Keyword "TDMS" is not in the list
I am getting the error: Keyword "TDMS" is not in the list when attempting to use the DataFileLoadRed command in DIAdem.  does this command not supprt the TDMS loader?
Any thoughts?
Ben
(5,729 Views)
Hi Ben,
It is supported.  Would you please submit the line of code that is throwing the error?
Brad Turpin
DIAdem Product Support Engineer
(5,699 Views)
Brad,
Thank you for your response. Hopefully I am missing something obvious not implementing it correctly.
The code:
If FileDlgShow(DataReadPath,"TDMS", "Select the data file(s) to analyze",1) = "IDOk" Then
  For i = 0 to UBound(FileDlgNameList)
    Call DataFileLoadRed(FileDlgNameList(i),"TDMS","Interval Count",100,1)
The files in FileDlgNameList are tdms files.  Perhaps the error is referring to the name list?
Ben
(5,694 Views)
Hi Ben,
You're missing the 3rd parameter "ImportSelection".  Just add another comma or specify the group/channel subset you want to load.
Call DataFileLoadRed(FilePath, "TDMS", "[1]/Temp_A", "IntervalWidth", 1, eInterFirstValue , SectionBegin, SectionEnd)
Brad Turpin
(5,675 Views)
