DIAdem
Real32 data only saving integer values in Diadem 2014
There seems to be an issue with saving Diadem ".dat " in REAL32 format in Diadem 2014. When you save a file in this format, the data is only saved as an integer value. So for example, if you saved a -1 to 1V peak to peak sine wave in a REAL32 .dat file, clear the data portal, then load the file, you essentially now have a square wave.
I've checked this problem doesn't exist in previous version of Diadem and wasn't corrected in the recent service pack 1.
Just putting this out there to hopefully prevent other people losing data like I did...
(5,480 Views)
Hello David_Corelss,
Thank you for your feedback. For the old DAT file format it is reproducible and needs to be fixed for the next version. Meanwhile you can either use the "Real-64" mode with the old DAT file format or save your data as TDM files.
Greetings
Walter
(5,457 Views)
