DIAdem
Execute .js file through cmd on DIAdem
Executing a python file works and returns an output as shown in the code.
cmdVar = getCommandOutput("cmd.exe /c python C:\Temp\Hello.py")
MsgBox cmdVar 'Returns "Hello"
Function getCommandOutput(theCommand)
    Dim objShell, objCmdExec
    Set objShell = CreateObject("WScript.Shell")
    Set objCmdExec = objshell.exec(thecommand)
    getCommandOutput = objCmdExec.StdOut.ReadAll
End Function
However when trying to execute a node .js file by modifying the cmd command slightly it does not work even though the command actually works on command prompt.
cmdVar = getCommandOutput("cmd.exe /c node C:\Temp\Hello.js")
How do I fix this issue?
(3,052 Views)
Hi hysde,
I'm not familar the "node" command but I'm assuming it's from: https://nodejs.org ? A couple of suggestions:
  1. Have you tried using "runas" for elevated permissions?
  2. Do you need to open cmd.exe in the correct path? see: https://superuser.com/questions/834319/node-js-wont-run-from-cmd-exe-in-windows-7-x64
Workaround?
One of the most common ways this functionality is achieved is to redirect the output to a file and then read from the file. Check out this post for an example.
hope this helps,
Rebecca
(3,013 Views)
