DIAdem
Export graph and cell data from DIAdem to Excel
Hello. I am sungbae chi
Is there any way I export 'Report sheets' to Excel. I know that Data portal can be saved as 'xlsx' using plugin. But, If I want to export some specific format like 'report in DIAdem', not a TDMS type, How should I do?.
I attached pdf file what I made using script. My goal is make excel report file same as that. In detail,
1. I'm expecting a way to save 2D graph in Excel as a Image file
2. Is there any simple script function to save cell data in Excel from DIAdem.
I also attached other backup file(VBS,tdr, raw data..etc). It seems mass data. I feel sorry for that. But, I hope it helps understand my questions.
(4,343 Views)
Just to make it clear : you want to export 2D graphs and table from REPORT to Excel ?
CLAMaxime -- Kudos are a great way to say thank you
(4,324 Views)
Hello.
Yes. that's what I want to say exactly.
Do you know how to?
(4,321 Views)
To export data you can use the KB maybe : http://digital.ni.com/public.nsf/allkb/C9423530C340B77386256F5E0048F369?OpenDocument
To export graphs to Excel, I'm not quite sure yet. I'll have a look at it.
(4,319 Views)
Thank you for your response.
I thought that link shows channel & data information exporting to excel. It's hard to finding graph and table case.
If you find any good solution, please share with us.
Thanks.
(4,287 Views)
For the table, do you want to export it as a picture too ? If no, then using the data in the DataPortal to transfer it to Excel is the best way. Even if you have to pre-process the data before adding them to your Sheet.
(4,281 Views)
