DIAdem
Exit DIAdem Without Prompt to Save C#
So I have written a C# program that uses DIAdem to extract data from a file.  It work great thanks to some help I asked for a few days ago but I am looking for one change to make the program's use even simpler.
I am using TOCommand oDIAdem = new TOCommand( ); to control DIAdem within my C# program which works great, but I am hoping there is a way to supress the exit dialog that comes up when the program ends.  I have attached a screenshot of the exit dialog that displays.  It isn't a huge problem, but I'd like to make the program as simple as possible for the person using it.  Any and all help is greatly appreciated.
Thanks!
(5,438 Views)
Hi Kub85
Try the command FileModification
http://zone-test.ni.com/reference/en-XX/help/370858L-01/varoff/filemodification/
FileModification = "ignore"
Hope this helps.
Winfired
(5,418 Views)
Hey winner, thanks for the suggestion.  I did a search before posting this question and I found the same solution you have suggested here.  Unfortunately I am not sure how to actually call this command.  Please bear with me if what I tried is totally off base but I am really new to NI products.  I ran the command "oDIAdem.CmdExecuteSync ( "FileModification = \"ignore\"" );" but it did not run properly.  Again my program is in C# and I am using the TOCommand to create a DIAdem object which I pass commands to.  Thank you again for your assistance so far and thanks for any further help anyone can give me.
(5,408 Views)
Accepted by Kub85
oDIAdem.CmdExecuteSync("datadelall(1)")
should be an easy workaround. It will just clear the portal.
(5,388 Views)
Worked like a charm!  I really appreciate the help.  I've marked this as the solution. Thanks!
(5,371 Views)
