DIAdem
Expand a table to next sheet or lengthen the currect sheet
I have one table on a report sheet which shows a data of channel group A. Channels of A have a length of 2. Therefore a table is short. But sometimes channels can be longer, e.g. 5. I want a table to scale automatically and be longer, or the table will expand to a new sheet. I cannot find an option for it. "Automatically increasing" means I should increase a length of table manually. But I want it to be done automatically. I wonder about a variable ActYPage, see help text: "Specifies the table page currently displayed in DIAdem REPORT when the tables expand vertically." It suggests there is a possibility I search for.
Thank you.
(3,018 Views)
Hi Sasha_62,
In DIAdem you specify with "Automatically increasing" the maximum table size and with “Row height” the maximum numbers of row which can be displayed. This must be defined manually. DIAdem automatically aligns then the displayed rows of the table to the number of values of a channel. Let’s say you have 2 values in a channel, then 2 rows are displayed in the table; if you have 5 values then 5 rows are displayed.
In case the number of values in a channel is higher than the maximal numbers of rows in the table, then you can navigate with the command icons below through the table.
I hope this helps.
Table navigation
Greetings
Walter
(2,989 Views)
Accepted by Sasha_62
Hi Sasha_62,
In DIAdem 2017 you can also activate "Print all pages with expanding tables completely" in the REPORT section of the DIAdem Settings.
If your table has "Automatically increasing" scaling activated, new sheets will be created in the output file automatically depending on the channel size which are displayed in the table.
Regards
Christian
CLA, CTA, CLED
(2,985 Views)
