DIAdem
Export Waveform to Diadem Automatically
I am having a data file with six channel data wrt elapsed time. the file is in lvm format. Now i require to plot seperate graph for each channel in a report. The report has to be generated via diadem. I have tried retreiving the data in a while loop, then building array and exporting the array data on loop termination ( EOF condition) but somehow it only exports the last set of data.
forum is not allowing me to attach the lvm datafile.
I hope for any possible suggestions.
Regards
(3,590 Views)
Hello Shakes,
The lvm file (if LVM is a LabVIEW Measurement File) should load straight into DIAdem, without any additional effort on your end.
Either drag&drop it from the NAVIGATOR view to the Data Portal, or go to the "File" menu in the NAVIGATOR and pick the "Open ..." function and then select "LVM File" as your file type in the "Files of Type" box ...
Ask if you have additional questions,
     Otmar
Otmar D. Foehner
(3,577 Views)
