DIAdem
display on certain channel rows in a 2d axis system
Hello, I have a set of data that has multiple steps within one channel. For example, rows 1-5 is step 1 of my test, rows 6-13 is step 2, 14-19 is step 3, etc. So, how do I have a 2d axis only display rows 1-5 of my channel?
(3,823 Views)
Accepted by topic author Mr. Spark Plug
Hi Mr. Spark Plug,
DIAdem graphs always display all the rows of the channels being plotted, so you will need to carve out the different rows into different channels.  I prefer to have a new Group for each set of rows (step, in your case), with the Channels in each Group named the same as the raw Channels they came from.  If you send me an example data set, I can send you a VBScript that does this automatically.
Brad Turpin
DIAdem Product Support
(3,810 Views)
Hello Brad, thanks for the response.  I was hoping this could be done as easily as it is with the 2d table.  That script will be easy enough to write, so I will take care of it.
Thanks for the help!
(3,805 Views)
