DIAdem
nilibddc cannot open tdms file
I am trying to open a TDMS file with nilibddc.  I downloaded the most recent version (9.1), and have just taken the example file included with the download and reassigned the file.  I get the error:
"Error: The Storage file cannot be opened"
I know this file is not corrupted as the C# measurement studio dll can open this file, but this lib cannot.  Is there a more recent version?  Is this a known problem?
(3,941 Views)
Hi Brian,
Did you use the example C++ code in the download to try to load your TDMS file?  Was there an example TDMS file that downloaded as well, and if so, were you able to use the C++ code to load the example TDMS file?
If you didn't use the example C++ code, would you please post your C++ code?
Would you also post your TDMS file?
Brad Turpin
DIAdem Product Support Engineer
(3,929 Views)
Hello Brian,
is there a logfile created beneath the tdms file (.tdms.log).
If so could you post this logfile.
Andreas
(3,850 Views)
