DIAdem
Exporting sheets with respective names
I'm using DIAdem 2020.
I want to use a script, that generates .emf Files with correct sheet names.
So far I only managed to create files where all sheets get the same name "Accelerations" with a number at the end.
This is the script I use:
Option Explicit
Dim MyFolders()
Sub InitMyFolders
ReDim MyFolders(1)
MyFolders(0) = "C:\Data"
End Sub
Call InitMyFolders
Dim oMyReportObj, oMyReportObjects, i
i = 0
Set oMyReportObjects = Report.Sheets
For Each oMyReportObj in oMyReportObjects
Call oMyReportObj.ExportToImage(MyFolders(0) & "Accelerations_" & i, eImageExportTypeEMF)
i = i+1
Can someone please help me?
Sebastian
(1,650 Views)
Accepted by topic author Sebastian-D
Hi Sebastian-D,
For your script code you find the name of the sheet here:
oMyReportObj.Name
Greetings
Walter
(1,607 Views)
Thank you Walter.
You helped me again!
Best regards
Sebastian
(1,594 Views)
