DIAdem
I want to put three y-axis in the 3D graph.
hi
I have a question. I want to know how to add the number of y-axis in 3D graph.
(1,633 Views)
Hi sally,
The 3D graph in DIAdem only allows one X, one Y and one Z axis each.  The 2D graph in DIAdem allows numerous Y axes.  Can you please describe the use case that motivates this request?
Brad Turpin
Principal Technical Support Engineer
NI
(1,563 Views)
Oh, okay. I'll find another way.
How can I see the Mda file?
(1,533 Views)
Hi sally,
You haven't mentioned an "Mda" file before.  Is this a data file format?  If so, we'll need to either find or create a DataPlugin for DIAdem to be able to load it into the Data Portal.  If it's not a data file format, what sort of information is stored in it... a picture, a video, a CAD modal, a test setup description?
Brad Turpin
NI
(1,459 Views)
