DIAdem
Extracting a 128 bit number from file with a binary plugin
Also, here is a test file I have been using.
Message 11 of 12
(447 Views)
Hey AJLNVA,
The "eTime" data type for a DirectAccessChannel in a VBScript DataPlugin is for efficiently interpreting datetime strings, usually all in one column, from ASCII data files.  You fill the File.Formatter.TimeFormat property with the datetime string representation to use ("DD/MM/YYYY hh:mm:ss"), then any "eTime" channels get converted from datetime strings to datetime values using that datetime format.
Brad Turpin
Senior Technical Support Engineer
Message 12 of 12
(429 Views)
