DIAdem
File Access Denied from C++
Sorry, this is my first time posting and I am not sure what board this should go to.
I am developing a standalone C++ (MSVC) application that reads TDMS data and am using the nilibddc.lib to read the data.  I am running into a problem that if more than one copy of my application is running and trying to access the same data file, I get a "File Access Denied" message, I assume because the file is not being opened in read-only mode.
Is there any way to specify that the files are to be opened read-only so that multiple applications can access the file at the same time?
I am currently using the DDC_OpenFile( ) function.
Ed Thomson
(3,966 Views)
Accepted by EdThomson
The DDC_OpenFileEx method let you specify the readonly option.
(3,954 Views)
Thanks - that worked.  Sorry, didn't see that one.
Ed
(3,940 Views)
