Home
Community
Discussion Forums
Most Active Software Boards
DIAdem
Topic
DIAdem
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
File.Formatter.NoValueSign
bm2cox
Member
04-04-2008
08:47 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Is it possible to have 2 values set for the File.Formatter.NoValueSign in the same plugin. If so how do I write the code.
Example:
File.Formatter.NoValueSign = "5"
File.Formatter.NoValueSign = "7"
0
Kudos
Message
1
of 2
(3,648 Views)
Reply
Re: File.Formatter.NoValueSign
KristenC
NI Employee (retired)
04-07-2008
06:10 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
No, you can not set 2 values for File.Formatter.NoValueSign. One possible solution would be to set one value and then manually loop through your values to set the other.
Kristen
Kudos
Message
2
of 2
(3,611 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
