DIAdem
File.Formatter.NoValueSign
Is it possible to have 2 values set for the File.Formatter.NoValueSign in the same plugin.  If so how do I write the code.
Example:
File.Formatter.NoValueSign = "5"
File.Formatter.NoValueSign = "7"
(3,642 Views)
No, you can not set 2 values for File.Formatter.NoValueSign.  One possible solution would be to set one value and then manually loop through your values to set the other.
Kristen
(3,605 Views)
