DIAdem
FileDlgShow Undefined Error
I can't seem to get the FileDlgShow to work.  I get an error "Variable is undefined: 'FileDlgShow' whenever I try to use it.
I am using version 10.2.  The below is straight from Excercise 5-1 in the Diadem Advanced Course Manual.
Option Explicit
Call DataDelAll(1)
DlgState = FileDlgShow("C:\Excercises\DIAdem Advanced\","*.tdm")
If (DlgState = "IDOk") Then
  Call DataFileLoad(FileDlgNameList(0),",")
  Call ChnSmooth("[1]/[2]","/Smoothed",12,"maxNumber")
  Call ChnPeakFind("[1]/[1]","[1]/Smoothed","/PeakX","/PeakY",5,"Max.Peaks","Amplitude")
  Call DataFileSave("Results.tdm","TDM")
  Call PicLoad("Smooth_2")
  Call PicUpdate(0)
Else
  Call MsgBoxDisp("Data loading has been aborted!")
End If
(4,875 Views)
Extra Info : If I take out the Option Explicit the error changes to "Type mismatch: 'FileDlgShow'
(4,874 Views)
Accepted by 2Pale4TX
Hello!
The FileDlgShow command is not part of DIAdem 10.2. It was implemented later in Version 11. You have to use the bulky FileNameGet command instead.
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(4,851 Views)
Thanks for your help!
I had a similar issue with FileDlgNameList  - is FileDlgFileName the equivalent command?
Sherry
System Test Engineer
(4,848 Views)
Hello Sherry!
Yes, you have to use FileDlgFileName. This string will contain all names and you have to split it on the | chracter to get an array.
Matthias
Matthias Alleweldt
Twigeater?
(4,846 Views)
