DIAdem
Find most recently updated file in folder or any one file name in a folder
Hello, I am looking for a quick method to find the most recently updated file name, OR really just one file name in a network folder.  My folder has many files inside, so I would prefer to not use any loops, etc.
My confusion starts here: I can use wildcards for some commands to get file information, such as:
FileExist(Directory & "*.TDM")
FileDateGet(Directory & "*.TDM", "fdModify")
I really just want one file name in the folder so that I can use DataFileHeaderAccess.  The most recently updated file would be best, but I'm flexible.
(4,566 Views)
Accepted by topic author Julia Dawkins
Hi Julia,
By any chance is this folder declared as a Search Area?  If so, then you could use a programmatic DataFinder query to return the most recently modified data file.
Otherwise I would use the filesystemobject in VBScript.  I can't seem to get the Item property of the file collection (fc) to work, but it's easy enough to exit the full loop after the first run through:
Directory = "C:\"
Set fso = CreateObject("Scripting.FileSystemObject")
Set f = fso.GetFolder(Directory)
Set fc = f.Files
FOR Each file In fc
  Msg = Msg & file.Path & vbCRLF
   Exit FOR
NEXT
MsgBox Msg
Also, it really shouldn't take long for the loop to find you the most recent file, even if you have lots of them in that folder:
Directory = "C:\"
Set fc = f.Files
FOR Each file In fc
  ModifyDate = file.DateLastModified
  IF MostRecentDate < ModifyDate THEN
    MostRecentDate = ModifyDate
    FilePath = file.Path
  END IF
NEXT
MsgBox FilePath & vbCRLF & MostRecentDate
Bad Turpin
Product Support Engineer
(4,549 Views)
Hi Brad, Yes, my folder IS declared as a Search Area, so that will work great. Thank you! Julia
(4,546 Views)
