DIAdem
z order of freeframe and freetext
I have a z ordering problem.  I create some freeframes and  text for statistics.  If i run the attached code on blank page, it works fine.  If I run with axis and other stuff, the frames are 'over' the text.  Oddly changing the order text before box reliably puts the text behind the box.  But not vice versa.  Please see attched pdfs.
Any clues on how to fix?
Jim
(4,067 Views)
Hello Jim,
We've tried to reproduce it but it seems to work fine. To analyze it a bit more in detail we would like to ask you to provide us the layouts you are using.
Greetings
Walter
(4,039 Views)
the problem seems to have gone away with restart of DD.
jim
(4,019 Views)
Jim,
Thanks for the update. Please let us know if this happens again and send us the layout file (TDR) so we can look into it.
Message Edited by Otmar on 04-22-2009 05:23 PM
Otmar D. Foehner
(4,016 Views)
