DIAdem
Forcing Diadem to save Time Data Explicit
Hello I have to load Diadem Data must do some calculation and save the data again.
The Data I load habe explicit Time Channels the Data I Save have Implizit Time Channels
how can I force Diadem to Save the Time Channels as Explizit Data ???
Many thanks in advance for any help !!
Thomas
(3,744 Views)
Accepted by topic author Tom_St
Hello Thomas,
yes there is a way to do that, but it requires to set a variable with a short VBS.
If a channel is loaded or created implicitely and expanded aftrewards DIAnem still remembers that the channel is implicite and tries to save it in that way.
To remind the type of channel, DIAdem uses the variable ChnDataType().
Use chndatatype(1) = "Explicite" to set the first channel to explicite (you will have to expand the channel first)
If you save the data afterwards, channel 1 will not be converted to implicite again.
Hope this answers qour question
regards
Ingo Schumacher
Systems Engineering Manager CEERNational Instruments Germany
(3,727 Views)
