DIAdem
GET Diadem installation Path from Batch
Hi all,
I have managed to start Diadem from batch using the following line:
"C:\Program Files\National Instruments\DIAdem 2015\DIAdem.exe"
"/cScriptStart('C:\ProgramData\National Instruments\DIAdem\Plugins\myScript.vbs')"
The problem is that if I want to share my application, some users might have Diadem installed in another path. How can I get the location of DIAdem.exe from batch?
Any comment or suggestion is welcome.
Thank you in advance,
Martin
(3,292 Views)
Hi Martin,
the variable ProgramDrv specifies the path and the folder where DIAdem is installed.
gemu
(3,243 Views)
Hi Gemu,
I appreciate your answer, but I'm afraid that's not what I was looking for. I want to get the path FROM BATCH.
Thank you anyway
Martin
(3,229 Views)
Accepted by iparra
I managed to do this approach:
Running this in a .bat file will show the following
@echo off
dir c:\DIAdem.exe /s /b
c:\Program Files\National Instruments\DIAdem 2015\DIAdem.exe
c:\Program Files (x86)\National Instruments\DIAdem 2015\DIAdem.exe
(3,228 Views)
