DIAdem
GPI extension: channel name truncate
I used the hDataObjChannelGet() function to create a channel in the Data Portal. But I notice that all names are truncated to 17 characters.
Is it a limitation of the GPI Extension?
What is the better solution to implement a channel name up to 50 characters ?
Fred
Message 1 of 13
(5,759 Views)
please use the GPI Function "hDataObjChannelGetW" instead of "hDataObjChannelGet" in a way like this:
  hDataObjChannelGetW(L"N_23456789N_23456789N_23456789N_23456789N_23456789N_23456789XXX",
                                         1024,
                                         1,
                                         eChannelDataTypeReal64,
                                         0);
Thomas
Message 2 of 13
(5,741 Views)
Message Edité par Fred91 le 01-24-2008 12:28 PM
Message 3 of 13
(5,737 Views)
Message Edité par Fred91 le 01-24-2008 12:27 PM
Message 4 of 13
(5,737 Views)
Message 5 of 13
(5,736 Views)
Message Edité par Fred91 le 01-24-2008 12:25 PM
Message 6 of 13
(5,735 Views)
Message 7 of 13
(5,735 Views)
Message Edité par Fred91 le 01-24-2008 12:24 PM
Message 8 of 13
(5,735 Views)
Thank you for the answer.
Two more questions:
   1. What is the best way to convert my CString in TDataWChar ?
    2. What is the difference between eDataObjCommentarySetW and eDataObjCommentarySetTDataWChar ?
Frederic
Message Edité par Fred91 le 01-24-2008 12:23 PM
Message 9 of 13
(5,735 Views)
Hello Frederic!
To convert a CString to Unicode you can use this code:
WCHAR* wszCommandT;
int    nLenT;
// determine the buffer size
nLenT = MultiByteToWideChar(CP_ACP, 0, sgCommand, -1, NULL, NULL);
// allocate result buffer
wszCommandT = new WCHAR[nLenT];
// Convert the string from ANSI to Unicode
nLenT = MultiByteToWideChar(CP_ACP, 0, sgCommand,-1,wszCommandT,nLenT);
if( nLenT > 0)
  // do something ...
// free result buffer
delete wszCommandT;
You can replace WCHAR with TDataWChar if you want.
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
Message 10 of 13
(5,713 Views)
