DIAdem
Generate a Waterfal
I've run into a problem.
I have a measurement file that contains multiple channels of raw data.
I would like to plot this data as a waterfall on my report.
So first I load my N ammount of channels from the TDMS File into my workspace.
In order to do that I generate 2 caluclated channels using the Analysis paletter.
I do the following:
Generate a time channel as the X axis based on the number of steps.
Generate a numeric channel for the Y asix that corresponds to the N number of channles I have.
So these channels land at the end of my measurement group.
When I try to create a waterfall plot.. during the selection of the Z Matrix
the TimeGenerated and LinerarGenerated channels are allways selected.
I can't deselect them using CTRL+ Left Click Shift + Left Click...
How can I define my Z Matrix ... so that I ommit those channels.... I only want the RAW data to be selected.
Maciej
(3,465 Views)
Attaching screenshot.
I don't know how to DESELECT the two channels from the Z matrix ...
(3,464 Views)
Dear Maciej,
I tried to reproduce your problem on DIAdem 2010 and I did not get the behavior you mentioned.
Could you please tell me what version of DIAdem are you using? A screenshot from "Help->About..." would be very helpful.
If it is possible please also attach the TDMS file with the data you want to process.
(3,437 Views)
