DIAdem
Generate a Worst Case (max) Channel from 2 or more channels
I'm creating a script to process a range of data channels, what is the easiest way to combine two channels (or more) in a way that the maximuim values are preserved in the result channel
eg
Channel 1     Channel 2      Results Channel
1                          5                       5
2                          6                       6
3                          1                       3
4                          2                       4
5                          5                       5
I'm currently using DIAdem 2019 64bit
(2,679 Views)
Accepted by topic author KBramley
Hey KBramley,
I'm no Diadem expert but would using the Channel Event Search (Free Formula) work for you?
ChnEventResultList = ChnEventFind("A>B", Array("A","B"), Array(Data.GetChannel("[1]/Data"),Data.GetChannel("[2]/Data")))
Call ChnEventCreateFilteredChn("/Results", ChnEventResultList, "[2]/Data", "[1]/Data")
Here I am comparing 2 data sets, and if A > B I replace the data in the results with the corresponding data from B.
(I set this up using the GUI and then used ctrl+shift+c to copy the formula to my clipboard.)
Hope that helps.
Best,
Jelmer
(2,621 Views)
Thanks Jelmer that has worked perfectly Smiley Happy
Best Regards
Kbramley
(2,600 Views)
