DIAdem
Generate an ISO-EGV file out of a dat-file
...but my dat-file has no entries about sample rate, time of first sample, bit solution etc. Is there another possibility rather to use the EGV_CHECK ?
(3,723 Views)
DIAdem doesn't support a function to generate a ISO-EGV file, but it is possible to create a VB-Script to do this. Therefore it is of course necessary to know the structure of this file type or you can ask an alliance partner (like MeasX) to do this for you.
Greetings
Walter Rick
(3,723 Views)
