DIAdem
Get the value of expression used in report template
I want to load the existing report template and want to fetch a maximum Ychannel value. But the Y channel is managed as expression in template, how to get the maximum Y channel value.
Y channel expression varies with template file.
Example:
Ychannel expression used in template: @@iif(Data.Root.ActiveChannelGroup.Channels.Exists("Ch1"), Data.Root.ActiveChannelGroup.Properties("Ch2").Value, "")@@
How to get the maximum Y value?
regards,
Durai
(1,659 Views)
Data.Root.ActiveChannelGroup.Channels(1).Maximum
(1,628 Views)
I want to read the expression in report template and the answer of expression needs to be saved in a variable.
Expression in template: @@iif(Data.Root.ActiveChannelGroup.Channels.Exists("Ch1"), Data.Root.ActiveChannelGroup.Properties("Ch2").Value, "")@@
 [ channels names and conditions will vary with respect to template loaded].]
Script to read the expression used in template and load the value of expression to variable.
ExpValue = script to read value comes from the expression.
regards,
Durai
(1,621 Views)
