DIAdem
GfSExcel.Dll nicht vorhanden in Diadem 2015
Servus miteinander,
ich habe heute Diadem 2015 installiert und wollte wie gewohnt (zuletzt genutzte Version Diadem 2012) die GfSExcel.DLL in den GPI-Erweiterungen "aktivieren" um .dat Dateien in Excel Files zu konvertieren. Leider finde ich zwar jede Menge anderer Dlls aber nicht mehr die Excel Dll. Wo bekomme ich denn die für Excel benötigte Dll her?
Danke für eure Hilfe im Voraus!
Beste Grüße
MaKo
(6,000 Views)
Accepted by MaKo1990
Hallo,
diese ist nicht mehr verfügbar in DIAdem 2015:
http://www.ni.com/pdf/manuals/375399a.html
GPI file filters are no longer available. Therefore the following filters are no longer available:
GfSExcel.DLL: Use the Excel DataPlugin Wizard instead.
Grüße
Christoph
Staff Applications Engineer
Certified LabVIEW Developer (CLD), Certified LabVIEW Embedded Systems Developer (CLED)
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved
(5,983 Views)
danke für die Info!
(5,980 Views)
Hi MaKo,
The GfSExcel.DLL is a 32bit dll.  It still ships with DIAdem 2015 32bit, but no longer with DIAdem 2015 64bit and any other future 64bit versions of DIAdem.
Brad Turpin
(5,958 Views)
Thank you for this information. Now i have this Diadem 2015 64bit - how can I convert .DAT -files to excel sheets (.xlsx)?
Excel 2003 (.xls) is not enough, because the numbers of lines are not enough. I would need the new Excel 2013-file type.
Beste regards,
MaKo
(5,917 Views)
Hi MaKo,
If the *.xls file format is not sufficient, then you need a new approach anyway.  The old Excel Export Wizard that no longer ships with DIAdem 2015 64bit only created *.xls files.  The simplest answer to your question is to load your *.DAT file into DIAdem, then export it to a new *.TDM or *.TDMS file.  Then you can right-click on that new *.TDM or *.TDMS file and select the context menu "Open with >> Excel Importer" in order to open that file in Excel.  You can also execute these actions programmatically in a VBScript if you need to.
Brad Turpin
(5,901 Views)
