DIAdem
Graphs dissapeared
After importing ASCII-data into DIAdem 9.1 and renaming the channels, all my graphs dissapeared, and I am not able to display them.
Does anyone have the same problem or a hint for me?
Thank you.
(4,105 Views)
Hello Glueck!
Do you use the number or the name orientated channel mode in DIAdem?
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(4,100 Views)
My settings say: name orientated.
Message Edited by Glueck on 09-26-2006 05:25 AM
(4,098 Views)
Hello Glueck!
In the name orientated mode DIAdem find the channels via a string compare. If you rename the cannels they will not be found anymore. There are two solutions: Use the number orientated mode or define the layout with the new names.
Matthias
Matthias Alleweldt
Twigeater?
(4,090 Views)
Thank you very much Twigeater, I'll try it.
(4,087 Views)
