09-21-2006 07:05 AM
float y \ x | 700 | 800 | 1.000 | 1.300 | 1.600 |
0,4 | 0,0000 | 0,0000 | 0,0000 | 0,0000 | 0,0000 |
0,5 | 0,0000 | 0,0000 | 0,0000 | 0,0000 | 0,0000 |
0,6 | 0,0000 | 0,0000 | 0,0000 | 0,0000 | 0,0000 |
0,7 | 0,0000 | 0,0000 | 0,0000 | 0,0000 | 0,0000 |
0,8 | 70,0000 | 10,0000 | 14,0000 | 20,3000 | 25,3000 |
0,9 | 70,0000 | 30,0000 | 34,0000 | 40,3000 | 45,3000 |
1,0 | 70,0000 | 30,0000 | 34,0000 | 40,3000 | 45,3000 |
1,1 | 70,0000 | 30,0000 | 34,0000 | 40,3000 | 45,3000 |
1,2 | 70,0000 | 30,0000 | 34,0000 | 40,3000 | 45,3000 |
1,3 | 70,0000 | 30,0000 | 34,0000 | 40,3000 | 45,3000 |
1,4 | 70,0000 | 30,0000 | 34,0000 | 40,3000 | 45,3000 |
1,5 | 70,0000 | 30,0000 | 34,0000 | 40,3000 | 45,3000 |
09-21-2006 01:46 PM
09-21-2006 01:50 PM
09-22-2006 09:42 AM
Hi Michael,
If indeed you do have this data in an ASCII file, then I would suggest a DataPlugin that maps the column header values (700 ..1600) to a y values channel inserted between the x values channel and the first z values channel. Then you've got it as a DIAdem matrix structure ready for 3D graphing or analysis.
Let us know if you need help with that,
Brad Turpin
DIAdem Product Support Engineer
09-22-2006 10:22 AM
09-25-2006 05:22 PM
Hi Michael,
I went ahead and created a DataPlugin for you that loads the file you attached. Is this a standard file format-- i.e. would it make sense to post this at the www.ni.com/dataplugins web site, or is this something special that really only you would be interested in?
Note that DIAdem 10.1 Beta has a new built-in Characteristic Diagram (Kennfeldanalyse) 3D plotting type-- this should make the rest of your steps in DIAdem much easier after loading the data.
Brad Turpin
