DIAdem
HOW TO INTEGRATE ACCELERATION-TIME FUNCTION?
I have a ground motion data at 0.02 sec time intervals and based on that I have the acceleration as a function of time. I need to find velocity of ground displacement,how can I integrate acceleration to find velocity and ground motion?
(4,494 Views)
Hello Mitrs
isn't that fairly trivial? In my DIAdem versions from 2.0 to 9.1, in the CALC module there is a base function 'Integrate', which does exactly what you'd expect.
There is a minor caveat in that even the slightest offset in a e.g. vibration channel will cause the integrator to accumulate this offset. If this is not desired, the offset has to be removed. E.g. by smoothing the channel in question with a generous smooth width (this would give offset only) and subtracting this offset from the original vibration channel.
Maybe you could include a chunk of data, some 20 or so values, to play around with.
regards
Michael
(4,481 Views)
Thanks for your answer, I have 1900 values of ground motion and I have made an excel sheet to calculate what I want.I wonder if I can integrate in that program,all points are in 0.02 time intervals.
Mitra
(4,479 Views)
Hi Mitrs,
Do you have DIAdem installed?  If so, would you please go to the ANALYSIS panel and select the "Integration" function in the "Basic mathematics" palette and give that a try?
Please let us know how that works,
Brad Turpin
Product Support Engineer
Naitonal Instruments
(4,467 Views)
