DIAdem
save ascii file with configuration
I have a text file (origin file) (separator = vbtab) with the following structure:
First line contains names of channel and others lines are data
Name1 Name2       Name3 . . . .
 45,4     dfr        17/05/2009..........
 34,1     fgh        13/04/2008.........
1)For load of data I use *.stp filter and I create my channels with data:
Group1/Name1;
Group1/Name2;
Group1/Name3;..........
2) I change some values into my channels
3) I need to export my channels into a text file with the same structure of my origin text file.
I usually use: OpenTextFile writeline method.....
Is it possibile to save data from my channels to a text file with the structure of my origin file and use for it some filter (same of .stp) or others methods and don't write every line into a text file?
Yustas
(3,789 Views)
Accepted by topic author Yustas
Maybe those lines help
Option Explicit
dim csvFilename : csvFileName = "D:\temp\EXAMPLE.csv"
DataFileSave "<filename>" & replace(replace(csvFileName, "&", "&amp;"), "<", "&lt;") & "</filename>" &_
  "<delimiter>tab</delimiter><decimalpoint>,</decimalpoint><timeformat>DD/MM/YYYY hh:mm:ss</timeformat>" &_
  "<channelnames>yes</channelnames><startrow>1</startrow>", "CSV"
Greetings
Andreas
(3,777 Views)
Thank you AndreasK!
It work great!
(3,764 Views)
