DIAdem
High speed data acquisition with USB DAQ 6363 in DIAdem 2012 with DAC?
Dear All:
Does anyone know how to perform high speed data acquisition with USB DAQ 6363 in DIAdem 2012 with DAC?
I need to acquire data at a very high sampling rate 30kHz, for 16 channels. I tested to acquire data in DIAdem with DAC through  USB DAQ 6363 by either soft clock or hard clock. But it is not possible to acquire data by hard clock, and the maximum sampling rate of soft lock is no more than 1k. Whereas it is widely known  DAQ 6363 has a very high sampling rate, which works very well in labview or SignalExpree. Does anyone know how perform high speed data acquisition with USB DAQ 6363 in DIAdem 2012 with DAC?
Many thanks
(5,476 Views)
Hi jigli,
I tested it with a simulated 6363 and was able to measure 16 channels with 50kHz each in the hardware clock mode.
Greetings
Walter
(5,456 Views)
