DIAdem
chnconvexhull has a limit of 65535 values
chnconvexhull has a limit of 65535 values, can this be increased, I'm still using 11.1 but I could load a later version if this limatation is removed
Is the quickest solution partitioning in 65k chunks form into mini hulls, then making a final convex hull from the mini hulls?
Graeme
(5,394 Views)
I have tested the function with the latest version of DIADEm (2012) and it is still the same (maximum of 65532 values). So, I believe the best way around this would be to create mini hulls likw you mentioned and then combine them.
Hope this helps.
Thanks and Regards,
Thanks and Regards,
Supreeth.K
(5,310 Views)
