DIAdem
How cam diadem check if channel exist before loading channel with DataFileLoadSel
Dear,
My problem is simple. I my code I use DataFileLoadSel(..,...,..., "register") to load selectively channels from tdms file. However, from one file to another the channel I want to load amy exist or not. How can I check this. In fact, if the channel does not exist then it generates an error message and my program ends.
Thank you for your help,
Louval
(5,723 Views)
Hi Louval,
If you want to load the channel if it exists each time, then I'd just put error handling around that call.  There are other options, but they're more complicated.
On Error Resume Next
Call DataFileLoadSel(DataFilePath, ...)
ErrNum = Err.Number
On Error Goto 0
IF ErrNum = 0 THEN ' Success
ELSE ' failure
END IF ' selected channel loaded
Brad Turpin
DIAdem Product Support Engineer
(5,700 Views)
Hi Brad,
All I needed, as usual. This is great thank you so much.
Cheers,
Louval
(5,672 Views)
Hi Louval,
you can also check the Dataportal for existing channels, if you know the groupname or index of the group:
data.Root.ChannelGroups(Gruppenindex als Zahl).Channels.Exists("Name")
Kind Regards,
Philipp
AE | NI Germany
(5,620 Views)
