DIAdem
Measurement at a repeating Trigger
Greetings:
I have a test run that has a Trigger pulse. It repeats thousands of times depending on the test run.
I need to measure ( in my example) the “Velocity FDBK” Average and compare it to the “Velocity CMD” Average signal. I would like to be able to create a channel for the measurement results for each cycle that the pulse is active.
This is my attempt at the script, but I am having trouble with the looping.
I welcome any help ….please.
Thanks Spidey
(5,097 Views)
Hi Spidey,
which dataplugin do you use to import your file?
Which looping do you mean exactly?
Kind Regards,
Philipp
(4,986 Views)
Accepted by topic author Spidermansrevenge
Philipp:
Thank you for your interest in my problem. With the help of a fellow colleague we have solved my problem.
I was using a Astromed file (.DCR) . The looping was the signal measurements within the timing "Pulse".
Thanks   🙂
Spidey
(4,976 Views)
