DIAdem
How can I adjust a time channel (start time and end time) in DIAdem?
I want to adjust a time channel with 8 hours. Adjust the starting time from 03/16/2015 17:18:31 to 03/16/2015 09:18:31 (mm/dd/yyyy hh:mm:ss). Is there an easy way (as analysis or script)?
(5,255 Views)
Accepted by topic author Olem
Either use a script like this
Option Explicit
data.Root.Clear
dim chObj : set chObj = data.root.ChannelGroups.Add("group").Channels.Add("time",DataTypeChnDate)
chObj.Values(1) = CDate("03/16/2015 17:18:31")
dim chNr : chNr = chObj.Properties("number").Value
dim offsetInSeconds : offsetInSeconds = 8 * 60 * 60
Call ChnOffset(chNr,chNr,"free offset")
or use
   Analysis.Basic Mathematics.Offset Corrections
and add offset in seconds as "Add any offset"
(5,247 Views)
