DIAdem
Could not initialize USI for Report
I have DiAdem 2012 SP1 installed.  All of a sudden every time i try to open it i get an error message saying  "Could not Initialize USI Report" see attached.
I have tried uninstalling and re-installing DiAdem but it made no difference.
I tried following the instructions in this post
http://forums.ni.com/t5/DIAdem/Errorcode-1906/m-p/810319/highlight/true#M9682
but when i double click the URI files i get an error message (attached).  My URI's are also in C:\Program Files (x86)\National Instruments\Shared\USI\Bin since i am on a 64 bit.
I have Windows 7 64bit, LV2013 and a lot of other NI software installed.
Message 1 of 13
(8,988 Views)
Looks like there is something wrong or missing in your installation.
Can you please check usiReg.exe for missing dependencies as described below:
1. Download and unzip Dependency Walker: http://www.dependencywalker.com/depends22_x86.zip
2. Start Dependency Walker and open usiReg.exe: C:\Program Files (x86)\National Instruments\Shared\USI\Bin\usiReg.exe
3. Save the Dependency Walker Image and post it here or attach a screenshot of the module tree
Message 2 of 13
(8,961 Views)
Hi usac,
I have attached the image.
Message 3 of 13
(8,926 Views)
Message 4 of 13
(8,924 Views)
Thanks a lot for the images. My best guess is that the 32bit and 64bit binaries are mixed.
Can you please post the content of two registry keys as follows:
1. Open regedit
2. Navigate to HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Common\Installer\
3. Post the content of NISHAREDDIR64
4. Navigate to HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\National Instruments\Common\Installer\
5. Post the content of NISHAREDDIR
Message 5 of 13
(8,904 Views)
The NISHAREDIR64 Contenets are
C:\Program Files\National Instruments\Shared\
I do not have NISHAREDIR in HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\National Instruments\Common\Installer
Message 6 of 13
(8,902 Views)
That's curious, does the folder itself exist?
If yes, can you please post the content as shown in the attached image?
Message 7 of 13
(8,882 Views)
Sorry, my bad i was looking in the wrong place.  The contents of NISHAREDIR are:
Message 8 of 13
(8,876 Views)
Hi USAC,
Any ideas what might be happening?
Message 9 of 13
(8,802 Views)
Sorry for the late response. We were trying to reproduce the error without success until now.
Therefore we would like to ask you to perform the following steps:
Check dependencies:
1. Start Dependency Walker and open usiEx.dll: C:\Program Files (x86)\National Instruments\Shared\USI\Bin\usiEx.dll
2. Switch on full path (F9) and post the saved Dependency Walker image here.
Check registry entries:
1. Open regedit
2. Navigate to HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Common\USI\
3. Post the content of binDir
4. Navigate to HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\National Instruments\Common\USI\
5. Post the content of binDir
If possible, please post the zipped contents of the USI bin dir:
C:\Program Files (x86)\National Instruments\Shared\USI\bin\
Thanks a lot
Message 10 of 13
(8,688 Views)
