Hi SriramSharma
In DIAdem REPORT, the 4th panel of the left hand side, you create multi-page reports from 2D&3D graphs, tables, pictures and texts.
When you save this templete is stores into an XML based file formate that DIAdem reads called TDR. This is so you can resue these templates with what ever dataset you want.
However you also have the choice from the file menu in DIAdem REPORT (4th panel) to export to an HTML report.
After you have desinged you template, and are displaying data, select "HTML Export" from the file menu in DIAdem REPORT. This will save your file in a format that is compatible with web browsers.
Let me know if you have any additional questions
Tom Ferraro
DIAdem Product Manager
512-683-6841
