DIAdem
How do you create a menu item in diadem user dialog boxes?
I dont mean adding a menu to the diadem view through 'MenuItemAdd'. I need to add it to a user dialog box. Know an ActiveX control that can be used for this?
(3,932 Views)
you can use the Microsoft Toolbar control version 6 for example.
I attached a SUD dialog, which uses this control.
Thomas
(3,932 Views)
Hi Thomas
Thanks for the reply but I can't seem to open the file you attached. It gives me a 'invalid file format' error when I try to open it in the dialog editor.
Anne
(3,932 Views)
the reason for this "invalid file format" might be that I use a DIAdem version, which is different from you version.
I have described the steps, which I did in the attached document.
Thomas
(3,932 Views)
Hi Thomas
I just followed your instructions and it worked. Thank you very much for your reply and for taking time to put it all together in such a easy way.
Anne
(3,932 Views)
