DIAdem
How to add a menu item to the toolbar?
I try to add a menu item to a module toolbar. However, the methods MenuItemAdd and MenuItemInsert did not work for me. There was no icon, no placeholder, not anything. Deleting of DIAdem predefined icons worked well.
I tried this one:
call MenuItemAdd("SCRIPT", "I", "MENUITEM", "TestName", "PicDelete")
I also tried all combinations of Modules, I, I.1, MenuItem, Unknown, Separator, etc. Nothing produced any result.
Does anyone have a hint for me?
thanks in advance,
Alex.
(3,758 Views)
Hello Alex Maier,
with DIAdem 10.0 we provide the following example: "User Defined Menus". Attached you find the relevant script commands.
I hope this will help you.
Greetings
Walter
(3,755 Views)
First, thanks for your answer.
Actually, it does not solve my problem. This script installs a new menu in the menu bar, not in the toolbar.
I want to add a new icon in the toolbar with the parameter "I" as the second parameter. But the toolbar doesn't show up a new icon.
BTW: In my opinion it is risky to use
Call MenuReset
Even in a demo script since it will delete previously installed menu entries, too.
Is there a possibility to install a new icon in the toolbar?
thanks,
Alex.
(3,751 Views)
Sorry, I misunderstood your question. No, currently we don't support changing the toolbars in DIAdem. But - as you already know - it is possible to cerate own user menus. I will add your suggestion - to have user defined toolbars - in our suggestion list.
Greetings
Walter
PS Thank you for your menu tip.
(3,748 Views)
