DIAdem
How to assign values to certain parts of a channel with VBS?
I need to modify  a continuous part of a channel to a constant, like A(30:50)=1 in MATLAB. It can be done with a for loop but with very low speed. I tried e.g. ch(10:40,5)=1 which doesn't work. And I can't think of a good keyword to search in help documents.
(5,630 Views)
Accepted by reko34
Hi reko,
If it's really just 30 values, then direct Channel.Values(i) access will be plent fast.  If it's a lot more values, and if you have them in another channel, then you can use the DataBlCopy() command.
To find a selection of useful commands like this, go to the Help system, select the "Contents" tab, open the "Programming Reference" node, then the "Thematic Programming Reference" node, then click on "Working with Data".
Brad Turpin
National Instruments.
(5,610 Views)
Thanks for the advice! It's a good start position to learn many useful commands. I also discovered chdx is far more efficient than chd. So it's also acceptable to use loop functions.
(5,586 Views)
