DIAdem
How to automatically create bands of software and add to a 3d axis system?
I am looking to automatically create bands of 1000 data points for 2 channels across every 3600000 across data that has in total 360000000 data points. These bands are going to be labelled 1 to 100 and that will be plot along a 3d axis with the 2 channels. Is there some form of script I could use to do this?
Cheers
(2,600 Views)
Thank you for posting this question. I would like to check up on this post since no one in the community has gotten back to you yet.
3D data in DIAdem can come in two different structures: Triplet and Matrix. A triplet plot will be like a line in 3 dimensions, while a Matrix gives a surface. I have found an article on this that should be helpful: http://zone.ni.com/reference/en-XX/help/370858K-01/genmaths/genmaths/calc_3d_organisation/
Depending on what you want to achieve, you will have to use either of these types. If you want to generate a channel with a script the syntax is described here: http://zone.ni.com/reference/en-XX/help/370859J-01/procauto/procauto/procauto_group_channel_generate...
Sara
(2,559 Views)
