02-28-2018 11:35 AM
We have just upgraded to DIAdem 2017. I was using 2014 and created a function using the "Pulse Detection" module and now the same script crashes out using 2017?
I use this function to find my rising and falling points in a ramp. Any Ideas?
03-01-2018 05:34 PM
Hey Spidermansrevenge,
Does this happen with the same parameters and data set in 2017? Hopefully the behavior is consistent between the two versions but it sounds like it may not be. If the two different versions deviate in how they analyze the same file, we'll have to do some digging internally to figure out what went wrong.
03-02-2018 05:35 AM
Looking into the problem further, I found a different file with a different Time /Date format that worked fine on 2017 ver.
Yeah The 2014,2015 versions work fine before,but I can't get the "Pulse start times" and "Index pulse start times" to function on the attached file format.
Thanks for looking into this
