DIAdem
How to calculate a speed from a displacement transducer?
I'm using wire displacement transducers that give me an input (the position) in milimeters (from 0 to 1000mm).
From this input, I would like to calculate the speed of the wire .
The speed is usually the first derivative of the position in relation to the time.
Does someone know how I can calculate this in DiademDAC?
Thank you for your help!
(3,566 Views)
Hello Jean-Kevin,
Attached you find an example for that.
Greetings
Walter
(3,522 Views)
