DIAdem
How to derive a signal using DIAdem DAC
Hello
I am a new diadem DAC 10.2 user. I have started working with Dac dialog boxes. For my application i use displacement sensors in order to obtain a speed curve after deriving the incoming signal (displacement curve).
Is there a simple way to derive a incoming signal and then display the converted signal as a new curve.
Many thanks for your answer.
Regards
Driss
Ps : acquisition card : NI DaQ Card 6036E
(3,680 Views)
Hello Driss,
Yes, you can use the F(x)-Block to calculate something. The result is a new signal which can be displayed in addition.
Greetings
Walter
(3,610 Views)
