DIAdem
How to change the "Report object" name in the "Configure DIAdem Report" dialogbox?
Problem description:
I want to creat a report and change the text in program, such as the example showed in labview(Changeing Text and Output File.vi).  Double click the "DIAdem Report" icon in the Block  Panel and the "Configure DIAdem Report" dialog box appears. We can find "Report object" under the "Configure Report".
My question is how to change the name list under the "Report object"? The names listed in the example were very intuitionistic, but if you create  text objects in the report, the Report object names were assigned auto, the names were "Text1, Text2, etc." How to change the name "Text1" to "TestMember"?
(3,104 Views)
Hello yangafreet,
please post again if this thread does not answer this question.
thanks
Ingo Schumacher
Systems Engineering Manager CEERNational Instruments Germany
(3,079 Views)
