DIAdem
How to change the tdms-File icon?
Hello
for some unknown reasons some of my tdms-files have different icons when I open the tdms files in Diadem. Some have
a sandglass icon and only change the icon when I click on the "+" symbol of the file itself.
Does anyone know this issue and how can I solve it automatically in order not having any sandglass icons anymore?
thanks in advance
Message 1 of 18
(7,521 Views)
Hi Norick,
the hourglass means that these files are beeing indicated by the datafinder. This might take a while.
If you update the view (F5), they should appear like the other files. This is also what happens when you press the plus.
Cheers, RMathews
Ramona Lombardo
Applications Engineer, NI Germany
Certified LabVIEW Developer
Message 2 of 18
(7,484 Views)
Hello Mathews
thanks for the response. Is it possible to do it automatically in Diadem or with a Labview code?
cheers
Message 3 of 18
(7,482 Views)
You can try searching the web how to send via VBScript a F5 command and use that in SCRIPT.
For LabVIEW here you have an example.
Ramona Lombardo
Message 4 of 18
(7,470 Views)
Accepted by topic author Norick_17
Hi Norick_17,
the hourglass is presented for the case DataFinder did not already index these files.
This could be of several reasons:
  • There are a lot of never indexed file in that folder, so it takes a while for DataFinder to index -> This is when F5 helps to refresh the display
    The script code for this is: Navigator.Display.CurrDataFinder.Browser.RefreshAll
  • The indexing process has stopped for a different reason. You can manually trigger re-indexing n MyDataFinder or DataFinder Manager by right-click on the folder and choose "Index Folder"
    The script code for this is: Navigator.Display.CurrDataFinder.GetDataFinder.Indexer.IndexFolder
Greetings from cloudy Aachen
Stefan
Message 5 of 18
(7,380 Views)
Hello Stefan
this is exactly the solution I was looking for 🙂
Thanks a lot!
Message 6 of 18
(7,364 Views)
Stefan
is there a way to update (refresh) the tdms files from Labview as well? How can I do it?
The problem is, that I can not find specific data in the tdms files from Labview due to the problem that the tdms-file(s) are not yet
indexed. In other words I would like to update (refresh) all tdms-files automatically without opening Diadem first and run a script
file for example.
best regards
Message 7 of 18
(7,284 Views)
Hi Norick,
Do you have the LabVIEW DataFinder Toolkit?
Brad Turpin
DIAdem Product Support Engineer
Message 8 of 18
(7,171 Views)
Hi Brad
yes I have.
Message 9 of 18
(7,163 Views)
Hi Norick,
You should be able to use the "Index File" or "Index Folder" method of the Invoke Node on the LabVIEW DataFinder Toolkit palette to "nudge" the files you want to index.
Brad Turpin
Message 10 of 18
(7,150 Views)
