DIAdem
How can i set the x-axis manually
I'm trying to analyze and display several spectra in the view mode.
At the moment I'm using the band-cursor to zoom in the needed x-axis areas. Sometimes I want to display all spectra with the same x-axis settings. Doing this with the curosr is not very exact.
Is there a possibility to change the x-axis settings without the cursor? Doubleclick on the graph only offers a manual change option for the y-axis.
Regards
pho_nox
(6,339 Views)
Hi pho_nox,
DIAdem sets the range of the x-axis in the VIEW module automaticly.
You can choose  between  the index and a time-channel.
Kind Regards,
Philipp
AE | AE-Germany
(6,321 Views)
Hi pho_nox,
It is not possible in DIAdem 2014 and previous versions to change the range of the X axis of a VIEW graph without using one of the zooming functions that involve cursors (there are 2 of those).  If you use the zoom icon at the top left of the VIEW graph, it will not affect the X1 and X2 values of the VIEW cursor.
Brad Turpin
DIAdem Product Support Engineer
(6,293 Views)
Hi pho_nox,
like Brad has mentioned you can use two diagrams with cursor and zoom function.
Have a look at the attached Layout.
Best regards
Philipp
AE | NI-Germany
(6,260 Views)
