DIAdem
Is there a simple way to build a Labview program with a Diadem Viewer as part of
Is there a simple way to bundle a Labview Program with a Diadem Viewer that is built and then installed as part of a single installer?  In other words, can I develop a labview program that calls DIADEM and then distribute it as an end item program?
(6,319 Views)
Are you trying to add DIAdem as an installer item like you would with DAQmx in the LabVIEW Application Builder?
Or are you trying to write a LabVIEW VI that installs DIAdem?
(6,267 Views)
(6,249 Views)
Hi id,
DIAdem can only be installed with its standalone installer.  You could set up your built LabVIEW application installer to kick off the DIAdem installer after installing the LabVIEW application.  The DIAdem installer also supports several command line options such as no user interaction, if that is needed.
Brad Turpin
DIAdem Product Support Engineer
(6,244 Views)
How would you do that?
(6,217 Views)
See the last topic of this KB:
http://digital.ni.com/public.nsf/allkb/51413B120232519386257A130056C937
"Automating the Installation of the NI Products"
(6,194 Views)
